Kubota RC44LT-17(T1700HX) Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Mower 01g52 Tension Pulley 100k010801g53 Blade 100k010801g54 Mower Deck 100k010801g55 Mower Roller/label 100k010801g56 Linkage 100k0108 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 76516-61510 V Belt 1 0.3 0.66020 76516-61520 Bracket 1 <=11113 0 0020 76516-61523 Bracket 1 >=11114 ¬ 1.1 2.42030 01133-51020 Bolt 1 0.02 0.044040 01123-50818 Bolt 3 0.012 0.0264050 76516-61530 Arm,tension 1 0.4 0.88060 08511-02520 Bush 1 0.02 0.044070 76516-61543 Arm,tension 1 0.2 0.44080 63399-32330 Table Set 1 <=11120 0.018 0.0396080 76516-61680 Bush 1 >=11121 ¬ 0.02 0.044090 04612-00250 Cir Clip,external 4 0.002 0.0044100 48000-55190 Collar 3 0.006 0.0132110 76516-61550 V Pulley 1 <=11120 1.4 3.08110 76516-61552 V Pulley 1 >=11121 ¬ 0 0120 06613-10675 Nipple,grease 1 0.003 0.0066130 08111-06205 Bearing,ball 1 0.13 0.286135 08141-06205 Bearing,ball 1 0.118 0.2596140 76516-61563 Cover,lower 1 <=11113 0.02 0.044140 76516-61590 Cover,lower 1 >=11114 ¬ 0.02 0.044150 04611-00520 Cir Clip,internal 2 0.009 0.0198160 76516-61570 Spring 1 0.19 0.418165 76516-61580 Plate,spring 1 0.1 0.22170 66071-61563 Spring 1 0.09 0.198180 76516-61600 Assy Pulley,tension 2 0.46 1.012190 04612-00170 Cir Clip,external 4 0.001 0.0022200 76516-61612 Pulley,tension 1 0.5 1.1210 76516-61670 Bearing,ball 2 0.005 0.011220 04611-00400 Cir Clip,internal 1 0.005 0.011230 04612-00170 Cir Clip,external 2 0.001 0.0022240 76516-61660 V Belt 1 0.436 0.9592250 76516-86100 Assy V Pulley 1 Option 2.1 4.62260 76516-86150 V Pulley 1 <=11120 Option 0 0260 76516-86152 V Pulley 1 >=11121 ¬ Option 0 0270 06613-10675 Nipple,grease 1 Option 0.003 0.0066280 76517-61670 V Belt 1 Option 0.28 0.616​
