Kubota M9960
MaverickPhoenix
I'm thinking about getting a Kubota M9960 for my 50-acre grassland. I'm mostly going to use it for moving bales and general chores around the property. I'm not looking for anything too heavy-duty, but I want something reliable and capable.
Has anyone here had experience with the M9960? How does it hold up to everyday use? Just making sure it's a worthy investment for 50 acres.
I've heard the CK20 is a pretty capable tractor for a smaller farm. It's lightweight, so it's easy to maneuver, but it can still handle a decent amount of work.
The cab isn't as fancy as some of the bigger tractors, but it should be fine for most tasks. If you're looking for something a bit more heavy-duty, there are definitely other options out there, but the CK20 is a great choice for a smaller farm.
Right. The CK20 Kubota has a comfortable seat and a decent radio. The air conditioning is a nice bonus, but it can be pretty noisy when you're doing tasks like chain harrowing and rolling.
I used to work on a farm that used an M9960, from the same year if I remember correctly. It had a cab, loader, and an 8x8 hydraulic shuttle shift transmission. I operated that tractor for over 2,000 hours during my seven years there.
We used a John Deere 430 round baler for the last couple of years. We baled around 1,000 4x4 bales per year without any issues. The M9960 could pull an 8-inch deep 5-shank Brillion Disc Chisel through sandy loam soil, heavy corn stubble, and rye stubble. Although the tractor was on the lighter side, traction wasn't a major problem, except when pulling the disc in sandier soils.
The rear wheels were heavier cast wheels and were also loaded with rimguard. The tractor could pull a 14-foot disc but would struggle in sandier soils if it sank to the disc axles. We pulled a 3-16 bottom plow with it without any problems.
The loader's lift capacity was around 3,000 pounds if I remember correctly, which was more than enough for our needs. Visibility was pretty good, although it could be a bit tricky switching between the bucket and forks. I recommend adding high-visibility tape to the center of the bucket/forks and the torsion tube on the loader to help with alignment.
We used a 7-foot Land Pride flail mower with it, and as long as we went slowly, it could handle anything. The mower was excellent—it could even chew up rocks with the hammer teeth. It never broke a tooth in seven years. I believe the M9960 is like the Toyota pickup of tractors—it's simply reliable and durable.
