Kubota LA272 Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Frame/boom 01a00101 Main Frame 100k0553hydraulic System 01a10101 Cylinder/hydraulic Hose 100k055301a10301 Hydraulic Tube 100k055301a104 Hydraulic Hose 1 100k055301a10501 Hydraulic Hose 2 100k0553frame/boom 01a30001 Brace 100k055301a30101 Boom 100k0553hydraulic System 01a50101 Control Valve [3-position Valve Kit] 100k055301a50103 Control Valve [4-position Valve Kit] 100k055301a50301 Control Valve [component Parts] [3-posi.valvekit]100k055301a50302 Control Valve [component Parts] [4-posi.valvekit]100k055301a50401 Control Lever [3,4-position Valve Kit] 100k055301a70101 Cylinder (Boom) [component Parts] 100k055301a70401 Cylinder (Bucket) [component Parts] 100k0553accessories 01a901 Accessories And Service Parts 100k0553 Ref.no Part No. Description Q'ty S.no. I/c Remarks Weight(Kgf)weight(Lb)010 7j043-90110 Frame Main(Label) 1 0 0020 75546-56410 Label Danger 1 1 0 0030 75567-56420 Label Danger 2 1 0 0040 75546-56450 Label Caution 1 1 0 0050 75540-62360 Label Control 1 0 0060 01073-51435 Bolt 4 0.063 0.1386070 75599-33016 Washer Spring Lock 4 0.08 0.176080 01073-51230 Bolt 4 0.041 0.0902090 75599-32015 Washer Plain 4 0 0100 04512-50120 Washer Spring 4 0 0110 01053-51235 Bolt 6 0.042 0.0924120 04512-50120 Washer Spring 6 0 0130 7j043-90130 Frame Side Lh(Label) 1 0 0140 75546-56430 Label Danger 3 1 0 0150 75546-56440 Label Warning 1 1 0 0160 75580-56370 Label Lubricate 1 0 0170 7j043-90140 Frame Side Rh(Label) 1 0 0180 75546-56440 Label Warning 1 1 0 0190 7j043-56710 Connector Side Frame 1 0 0200 75599-04625 Hex.bolt 2 0 0210 75599-31066 Hex.nut 2 0 0220 75599-33016 Washer Spring Lock 2 0.08 0.176230 7j043-56810 Pin Mount 2 0 0240 75599-56004 Hairpin Cotter 2 0 0​
