Item Part No. Description Book Engine 01t001 Crankcase 100k003201t002 Cylinder Head 100k003201t003 Gear Case 100k003201t004 Bearing Case 100k003201t005 Breather 100k003201t006 Inlet Manifold 100k003201t007 Valve Rocker Arm 100k003201t008 Head Cover 100k003201t009 Camshaft 100k003201t010 Piston Crankshaft 100k003201t011 Flywheel 100k003201t012 Nozzle Holder 100k003201t013 Injection Pump 100k003201t014 Speed Control Plate 100k003201t015 Governor 100k003201t016 Dynamo 100k003201t017 Clutch 100k003201t018 Name Plate 100k003201t019 Nozzle Holder 100k003201t020 Injection Pump 100k003201t021 Dynamo 100k003201t022 Starter 100k003201t023 Oil Pressure Pump 100k0032transmission 01t024 Transmission Case 100k003201t025 Case Cover 100k003201t026 Axle Case 100k0032front Axle/front Wheel 01t027 Wheel Hub [america] 100k0032clutch 01t028 Clutch Rod 100k0032transmission 01t029 1st Shaft 4th Shaft 100k003201t030 2nd Shaft Front Wheel Shaft 100k003201t031 3rd 5th Pto Shaft 100k0032rear Axle/rear Wheel 01t032 Differential 100k0032speed Change Lever 01t033 Aux. Speed Change 100k003201t034 Rotary Speed Change 100k0032brake 01t035 Brake 100k0032hydraulic System 01t036 Hydraulic Pipe 100k0032transmission 01t037 Hydrostatic Transmission 100k0032hydraulic System 01t038 Control Valve 100k003201t039 Hydraulics 1 100k003201t040 Hydraulics 2 100k0032steering 01t041 Steering 100k0032brake 01t042 Brake Rod 100k003201t043 Release Rod 100k0032speed Change Lever 01t044 Speed Change 1 100k003201t045 Speed Change 2 100k0032hood(Bonnet)/chassis 01t046 Seat 100k0032labels 01t047 Name Plate 100k0032clutch 01t048 Clutch Housing 100k0032front Axle/front Wheel 01t049 Front Wheel Support 100k0032cooling Water System 01t050 Radiator 100k0032hood(Bonnet)/chassis 01t051 Fender 100k003201t052 Bonnet 100k0032engine 01t053 Muffler 100k0032fuel System 01t054 Fuel Tank 100k0032electrical System 01t055 Battery 100k003201t056 Panel 100k0032
