Kubota B5200DT Instructions for Parts Books - Instruction Manual
Item Part No. Description Book Engine 01t001 Crankcase Group 100k003701t002 Cylinder Head Group 100k003701t003 Gear Case Group 100k003701t004 Bearing Case Group 100k003701t005 Breather Group 100k003701t006 Inlet Manifold Group 100k003701t007 Valve Rocker Arm Group 100k003701t008 Head Cover Group 100k003701t009 Camshaft Group 100k003701t010 Piston Crank Shaft Group 100k003701t011 Flywheel Group 100k003701t012 Nozzle Holder Group 100k003701t013 Injection Pump Group 100k003701t014 Speed Control Plate Group 100k003701t015 Governor Group 100k003701t016 Dynamo Group 100k003701t017 Clutch Group 100k003701t018 Name Plate Group 100k003701t019 Nozzle Holder Group 100k003701t020 Injection Pump Group 100k003701t021 Dynamo Group 100k003701t022 Starter Group 100k003701t023 Oil Pressure Pump Group 100k0037transmission 01t024 Transmission Case Group 100k003701t025 Case Cover Group 100k003701t026 Axle Case Group 100k0037rear Axle/rear Wheel 01t02701 Rear Wheel Group 100k0037clutch 01t028 Clutch Rod Group 100k0037rear Axle/rear Wheel 01t029 1st Shaft 4th Shaft Group 100k003701t030 2nd Shaft Reverse Shaft Group 100k003701t031 3rd 5th Pto Shaft Group 100k003701t032 Differential Group 100k0037speed Change Lever 01t033 Main Speed Change Group 100k003701t034 Aux.speed Change Group 100k0037front Axle/front Wheel 01t035 Front Drive Group 100k0037brake 01t036 Brake Group 100k0037hydraulic System 01t037 Oil Pressure Pipe Group 100k003701t038 Control Valve Group 100k003701t039 Oil Pressure Group 1 100k003701t040 Oil Pressure Group 2 100k0037steering 01t041 Steering Group 100k0037brake 01t042 Brake Rod Group 100k0037engine 01t043 Accelerator Pedal Group 100k0037hood(Bonnet)/chassis 01t044 Seat Group 100k0037labels 01t045 Name Plate Group 100k0037clutch 01t046 Clutch Housing Group 100k0037front Axle/front Wheel 01t047 Front Wheel Support Group 100k0037cooling Water System 01t048 Radiator Group 100k0037hood(Bonnet)/chassis 01t049 Fender Group 100k003701t050 Bonnet Group 100k0037engine 01t051 Muffler Group 100k0037fuel System 01t052 Fuel Tank Group 100k0037electrical System 01t053 Battery Group 100k003701t054 Panel Group 100k0037engine 01t061 Air Cleaner Group 100k0037fuel System 01t062 Fuel Filter Group 100k0037front Axle/front Wheel 01t063 Front Axle Group [b5100e] 100k003701t064 Front Wheel Group [b5100e-p B5100e-pt] 100k0037hydraulic System 01t065 3-point Linkage Group [b5100d-p B5100e-pb5100e-pt]100k0037​
