Item Part No. Description Book Engine 01t001 Crankcase Group 100k003501t002 Cylinder Head Group 100k003501t003 Gear Case Group 100k003501t004 Bearing Case Group 100k003501t005 Breather Group 100k003501t006 Inlet Manifold Group 100k003501t007 Valve Rocker Arm Group 100k003501t008 Head Cover Group 100k003501t009 Camshaft Group 100k003501t010 Piston Crankshaft Group 100k003501t011 Flywheel Group 100k003501t012 Nozzle Holder Group 100k003501t013 Injection Pump Group 100k003501t014 Speed Control Plate Group 100k003501t015 Governor Group 100k003501t016 Dynamo Group 100k003501t017 Clutch Group 100k003501t018 Name Plate Group 100k003501t019 Nozzle Holder Group 100k003501t020 Injection Pump Group 100k003501t021 Dynamo Group 100k003501t022 Starter Group 100k003501t023 Oil Pressure Pump Group 100k0035transmission 01t024 Transmission Case Group 100k003501t025 Case Cover Group 100k003501t026 Axle Case Group 100k0035rear Axle/rear Wheel 01t027 Rear Wheel Group [america] 100k0035clutch 01t028 Clutch Rod Group 100k0035transmission 01t029 1st Shaft 4th Shaft Group 100k003501t030 2nd Shaft Reverse Shaft Group 100k003501t031 3rd 5th Pto Shaft Group 100k0035rear Axle/rear Wheel 01t032 Differential Group 100k0035speed Change Lever 01t033 Main Speed Change Group 100k003501t034 Aux.speed Change Group 100k003501t035 Rotary Speed Change Group 100k0035brake 01t036 Brake Group 100k0035speed Change Lever 01t037 Oil Pressure Pipe Group 100k0035hydraulic System 01t038 Control Valve Group 100k003501t039 Oil Pressure Group 1 100k003501t040 Oil Pressure Group 2 100k0035steering 01t041 Steering Group 100k0035brake 01t042 Brake Rod Group 100k0035engine 01t043 Accelerator Pedal Group 100k0035hood(Bonnet)/chassis 01t044 Seat Group 100k0035labels 01t045 Name Plate Group 100k0035clutch 01t046 Clutch Housing Group 100k0035front Axle/front Wheel 01t047 Front Wheel Support Group 100k0035cooling Water System 01t048 Radiator Group 100k0035hood(Bonnet)/chassis 01t049 Fender Group 100k003501t050 Bonnet Group 100k0035engine 01t051 Muffler Group 100k0035fuel System 01t052 Fuel Tank Group 100k0035electrical System 01t053 Battery Group 100k003501t054 Panel Group 100k0035engine 01t055 Air Cleaner Group Except[overseas] 100k0035fuel System 01t056 Fuel Filter Group 100k0035
