Greetings. Trying to clear up some confusion on my part as to WHICH of the connectors mounted on my SVL-65 skidsteer are which. A site on youtube (Skidco?) has the host identifying the bottom 2 connectors of the 4 as High Flow (but if memory serves he is showing an SVL75 or SVL95 and made the comment that the SVL-65 is or might be different.) Adding to my confusion is Pg. 64 of my Owner's Manual in the right hand column under 'IMPORTANT: (High-Flow model only), the first bullet states "When relieving pressure, use the couplers of (1) and (2) in the preceding figure (figure at bottom of page in left hand column; inset with 1RAPQ00081B01.) That text leads me to think it is couplers 1 & 2 are the 'High Flow' but they are actually smaller physically than 4 & 5 so I'm guessing 4 & 5 are actually the High Flow connectors (not that volume equals pressure but it seems in these applications a larger volume would be desirable, as well. Thanks in advance.
