Hey Shane, I did a bit of research and here’s what I found and hope this helps:
It seems like the mid-PTO driveshaft is hitting the bottom when the deck is fully lowered. On the LX2620 paired with the RCK60-30BB, the shaft length is designed to ensure there's enough spline engagement when fully lifted and enough clearance when lowered. However, if the deck height linkages are adjusted too low, or if the incorrect front hanger brackets or spacers are used, the shaft might end up over-compressing.
Here’s what to check:
1. Driveshaft Length: Make sure the shaft can move freely throughout the entire lift range. When the deck is fully lowered, you should still have at least 1/4–3/8" of play before the yokes hit the bottom.
2. Deck Lift Linkage Adjustment: Double-check that the lift rods and stop bolts are set according to the manual specifications. If there's too much travel in the down position, it can push the deck lower than it should go.
3. PTO Shaft Orientation: Ensure that both splined yokes are aligned properly (phased) and that the locking collars are securely in place.
4. Mounting Points: Verify that the deck front mount pins and brackets are the right ones for the LX2620. Using mismatched hardware can alter the shaft geometry.
If you discover that the shaft is either too short or too long during its travel, measure both the compressed and extended lengths and compare them to Kubota’s specifications for the RCK60-30BB driveshaft. This will help you determine if it needs to be replaced or adjusted.
