orangeyouglad
- Oct 16, 2025
For residential jobs like small digs, landscaping, and working in tight spots, which Kubota mini excavator do you recommend?
For tight residential spots, you might want to look at the Kubota K008-5 or the U10-5! Between the two, the K008-5 is the champion of tight access because its undercarriage retracts to fit through a standard 36-inch gate, perfect for backyard work. But if you have slightly more room and need a little extra power or reach, the U17-5 is the way to go. It's a true zero-tail-swing machine, so you can pivot right next to a fence or house without knocking anything over. All three are excellent for small landscaping and utility digs!For residential jobs like small digs, landscaping, and working in tight spots, which Kubota mini excavator do you recommend?
