replacement for lift cylinder Kubota B219 FEL
BeachBro93
Member
City & State/Province
Maryland
my dad's kind of busy these few weeks, so he asked me to deal with his tractor. he got this kubota B219 FEL
I think just swapping them would save a ton of time compared to fixing the old ones.
Anyone know if there's a direct, bolt on replacement for the lift cylinders on this type?
You'll might have a slight problem finding a branded replacement but aftermarket cylinder with the proper size can do the job. You just need to measure the existing lift cylinders, pin-to-pin length (retracted and extended), bore, rod diameter, and stroke. You can try looking at the brands bailey hydraulics, surplus center, koyker.
Yeah, swapping's way quicker, so for that Kubota B219 FEL, you might luck out with a bolt-on swap ...so check Surplus Center or Bailey Hydraulics. Some aftermarket ones drop right in
I’d switch them out too, it’s faster. I haven’t found a real bolt-on, but a nearby hydro shop can usually match the specs pretty well. Just take the old one with you.
