L3200 rim replacement salt damage
load3rpro
I'm dealing with an L3200 that I've inherited, and the rims are pretty corroded from road salt damage. The two-piece 16x30 rims have seen better days. I've been looking for new outer rims, but I've noticed that the offset doesn't match the originals. Does anyone know of any aftermarket options that are more affordable than the $1200 Kubota is asking?
$1200 a rim from Kubota is nuts. A lot of folks end up going through places like Unverferth or even Miller Tire for outer rims. The key is matching the center disc bolt pattern and offset, and sometimes you've gotta shim a little. If you're not picky about OEM exact offset, aftermarket ag rims usually come cheaper.
Afaik, All States Ag Parts is cheaper but make sure to confirm the offset before ordering. My buddy had a similar issue, he used wheel spacers which allowed a different offset to fit without causing any stability issues.
