Kubota Rotary Mower Models RCK54-24B-EC,RCK60-24B-EC,RCK60-27B-ECRC60-24BR,RC60-27BR WSM Printed in Japan 2006 Code No.9Y011-17110 - Technical Manual
This symbol, the industry’s “Safety Alert Symbol”, is used throughout this manual and on labels onthe machine itself to warn of the possibility of personal injury. Read these instructions carefully.It is essential that you read the instructions and safety regulations before you attempt to repair or usethis unit. DANGER : Indicates an imminently hazardous situation which, if not avoided, will result indeath or serious injury. WARNING : Indicates a potentially hazardous situation which, if not avoided, could result indeath or serious injury. CAUTION : Indicates a potentially hazardous situation which, if not avoided, may result inminor or moderate injury. IMPORTANT : Indicates that equipment or property damage could result if instructions are notfollowed. NOTE : Gives helpful information. BEFORE SERVICING AND REPAIRING• Read all instructions and safety instructions in thismanual and on your machine safety decals.• Clean the work area and machine.• Park the machine on a firm and level ground, and setthe parking brake.• Lower the implement to the ground.• Stop the engine, and remove the key.• Disconnect the battery negative cable.• Hang a “DO NOT OPERATE” tag in operatorstation.​
