Kubota 05 Series Diesel Engine Workshop Manual Reprinted from KUBOTA WSM, 05 Series Diesel Engine (English language only) - Technical Manual
This Workshop Manual has been prepared to provide servicing personnel with information on the mechanism, service and maintenance of KUBOTA Diesel Engines 05SERIES. It is divided into two parts, "Mechanism" and "Disassembling and Servicing" for each section. Mechanism Information on the construction and function are included for each engine section. This part should be understood before proceeding with troubleshooting, disassembling and servicing. Disassembling and Servicing Under the heading "General" section comes general precautions, troubleshooting, lists of servicing specifications and periodic inspection items. For each engine section, there are "Checking and Adjustment", "Disassembling and Assembling", and "Servicing" which cover procedures, precautions, factory specification and allowable limits. All the engines that have been manufactures since January of 1994 are clean exhaust engines. The mark [E] in the WSM refers to the said clean engine. All information, illustrations and specifications contained in this manual are based the latest production information available at the time of publication. on The right is reserved to make changes in all information at any time without notice. Due to covering many models of this manual, illustration or picture being used have not been specified as one model.​
