Engine running hot causes and rixes
LazyGear
Hey, if your Kubota's engine is overheating when it's working hard, what things have you checked? Like, did you look at the cooling system, belt tightness, or try cleaning the radiator?
I flushed the radiator, took a look at the thermostat, and discovered there was a clogged screen behind the grille. That did the trick
Nice catch! I’d definitely take a look at the fan clutch and ensure the water pump is circulating correctly, those issues can creep up on you if the basics don’t fix it.
