You definitely test the battery voltage with the key in the start position. You can also try the jumper cable test.My 2016 B3350 is having trouble starting and frequently stalls. I just replaced the battery about a year ago. I have a safety switch installed, and I suspect it's causing the battery to drain quickly. What dp yall think??
Could be. I know the overuse of safety switches can be annoying, especially when they're constantly killing the engine and could be causing the drain.My 2016 B3350 is having trouble starting and frequently stalls. I just replaced the battery about a year ago. I have a safety switch installed, and I suspect it's causing the battery to drain quickly. What dp yall think??
